PREVIEWFILTER system variable
Selection preview filter
Specifies which entity types are excluded from selection previewing. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: |
Registry |
Range: |
to 63 |
Default value: |
1 |
Possible options: |
1: Exclude entities on locked layers 2: Exclude entities in xrefs 4: Exclude tables 8: Exclude multiline text entities 16: Exclude hatch entities 32: Exclude entities in groups |
