VOLUMEUNITS system variable
Volume units
Specifies a list of units used for displaying volumes when the volume bit of PROPUNITS is on. If empty, all volumes are displayed in the current drawing unit. When one or more units are selected in the VolumeUnits dialog box, the program uses the unit that is the best fit. The Format Volume Properties bit of the Property Units variable must be turned on.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
"in ft mi µm mm cm m km"
