ZOOMFACTOR system variable
Zoom factor
Specifies the incremental change in zoom with each mouse-wheel action, whether forward or backward. When zooming in, the incremental step decreases gradually allowing to focus on a particularly detail easily. Values between 3 and 100 are accepted. The higher the number, the more the change.
Type: | Short |
Saved in: | Registry |
Range: |
3 to 100 |
Default value: |
40 |
