BIM project info
About
The BIM Project Info dialog box shows information about properties, materials, compositions, profiles and spatial structures of the Project and Central databases. It allows you to import or export the database and set the project database as embedded or external. Project and Central databases of BIM models can be changed using this dialog box.
For more information about the Project and Central databases, see the article BIM data structure.
Setting the project database
  1. Open the BIM Project Info dialog box by typing BIMPROJECTINFO in the Command line and select the Project Database tab.
  2. To change the project database from Embedded to External or vice versa, select the desired option in the Project Database drop-down list.
    Note: The external database keeps the database independent from the current drawing. This is especially useful if you want to share the database between multiple models, for example when a model consists of several Xref drawings.
    • When switching from Embedded to External, the Select or create a Bricsys Library dialog box displays.
      Do one of the following:
      • Type a name in the File Name field to export the content of the project database to a new BSYSLIB file, then click the Open button.
      • Select an existing BSYSLIB file, then click the Open button.
        The current content of the project database is merged with the selected BSYSLIB file, including the imported libraries.
    • When switching from External to Embedded, the content of the external database is copied to the embedded project database.
  3. To specify the Project Database properties such as Region and Language, fill out the Region field and choose one of the language options in the drop-down list.
  4. Optionally, use the custom properties button to add material and composition custom properties in the Project Database.
  5. Press the OK button to accept it.
Setting the Central database
  1. Click the Central Database tab in the BIM Project Info dialog box.
  2. To select a BIM database file (BSYSLIB), click the Browse button of the Path field, then choose a database file in the Select or create a Bricsys Library dialog box.
  3. Optionally, tick the Set as default option to set the selected database as default library database for next projects.
Note: You can edit the default library database settings (DEFAULTBSYSLIBMETRIC and DEFAULTBSYSLIBIMPERIAL system variables) in the Settings dialog box under Program Options > System.
Adding profiles by importing XML or CSV files in the project database (BSYSLIB)
  1. In the Project Database tab, press the Import button that opens the Select xml/csv file to import dialog box.
  2. Choose the XML or CSV Library files and press the Open button.
The CSV Library files that add profiles must respect the below format:
The first row indicates the profile shape name (AsymmetricIShape, CShape, Circle, CircleHollow, CraneRailAShape, CraneRailFShape, Ellipse, IShape, LShape, Rectangle, RectangleHollow, RoundedRectangle, Trapezium, TShape, UShape, ZShape).
The second row must contain the names of the profile properties. The first 5 names are general profile properties (standard, name, type, size, material). The next names are the specific parameters for each shape of profiles.
// or # - can be used to add comment to the CSV files, lines starting with these characters will be ignored.
For example, a CSV file for import C-shape profiles should contain at least the following:
CShape
standard name type size material depth width wallThickness girth
General columns for all shapes are:
Available types:
Electrical,
Generic,
HVAC,
Structural Steel,
Structural Concrete,
Piping
Available materials:
Only existing
in project or in library
(use BLMATERIALS to check).
Mostly used - Steel.
Note:
  • Type and material names are case sensitive.
  • Empty fields are not yet accepted.
Right of the general columns are the columns that indicate the specific parameters for each shapes of profiles.
Below are the shapes of profiles with the specific parameters (in bold) necessary to be indicated for a successful import. The meaning of each parameter can be better understood from the profiles preview (BIMPROFILES/New profiles).
Shape of profile parameters Shape of profile parameters
AsymmetricIShape
overallWidth
overallDepth
webThickness
flangeThickness
filletRadius
topFlangeWidth
topFlangeThickness
topFlangeFilletRadius
centreOfGravityInX
LShape
depth
width
thickness
filletRadius
edgeRadius
legSlope
centreOfGravityInX
CShape
depth
width
wallThickness
girth
internalFilletRadius
centreOfGravityInX
Rectangle
xDim
yDim
Circle radius RectangleHollow
xDim
yDim
wallThickness
innerFilletRadius
outerFilletRadius
CircleHollow
radius
wallThickness
RoundedRectangle
xDim
yDim
roundingRadius
CraneRailAShape
overallHeight
baseWidth2
radius
headWidth
headDepth2
headDepth3
webThickness
baseWidth4
baseDepth1
baseDepth2
baseDepth3
centreOfGravityInY
Trapezium
bottomXDim
topXDim
yDim
topXOffset
CraneRailFShape
overallHeight
headWidth
radius
headDepth2
headDepth3
webThickness
baseDepth1
baseDepth2
centreOfGravityInY
TShape
depth
flangeWidth
webThickness
flangeThickness
filletRadius
flangeEdgeRadius
webEdgeRadius
webSlope
flangeSlope
centreOfGravityInY
Ellipse
semiAxis1
semiAxis2
UShape
depth
flangeWidth
webThickness
flangeThickness
filletRadius
edgeRadius
flangeSlope
centreOfGravityInX
IShape
overallWidth
overallDepth
webThickness
flangeThickness
filletRadius
ZShape
depth
flangeWidth
webThickness
flangeThickness
filletRadius
edgeRadius
An example of such a CSV file (templates_of_mostly_used_profiles.csv) for the most used profiles is stored in your Support folder in the following path:
C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V27x64\en_US\Support\Bim\Profiles.
The Appdata folder is a hidden folder by default, you may have to unhide folders first. This path can also be accessed by the SUPPORTFOLDER command.
The project filter
You can attach any number of tags to each Physical Material or Composition. Any string can be entered as a tag.
Each of the tags can be used as a filter on the database. There is a button at the top of each list (), to switch the filter on or off. If the filter is on, only Compositions and Physical Materials that match at least one of the filter tags will be listed.
The Filter button has three states:
  • If the project filter is empty, the button is not active (BIM Compositions panel) or is not available (Materials and Compositions editors).
  • The project filter is defined, but not active.
  • The project filter is defined and active.
    A tooltip shows the current project filter.
Setting the project filter
  1. Select the Filter tab page on the BIM Project Info dialog box.
  2. Check the tags you want to use in the filter.
