Creating text
The TEXT command places single lines of text in the drawing and optionally evaluates LISP expressions.
The MTEXT command places formatted paragraph text in a bounding box that limits the extent of the text.
Creating single line texts
- Do one of the following:
- Click the Text tool button (
) on the Draw toolbar or the Annotate / Text ribbon panel. - Choose Text in the Draw menu.
- Launch the TEXT command.
- You are prompted:
Text start point or [use defined Style/Align on line/Fit between points/Center horizontally/Middle (hor/vert)/Right justify/Justification options...]:
- Specify a point.
You are prompted:
Height of text <current height>:
- Press Enter or right click to accept the current height.
- Enter a value.
- Click a point to define the height graphically.
You are prompted:
Rotation angle of text <current angle>:
- Press Enter or right click to accept the current rotation angle.
- Type a value.
- Click a point to define the rotation angle graphically.
- Type the text, then press Enter.
A new empty text is created.
- Type the text.
- Press Enter to stop.
- (Optional) Keep adding texts then press Enter twice to stop.
Single line text justification options:
Creating multiline text
- Click the Multiline Text tool button (
) on the Draw toolbar or the Annotate / Text ribbon panel. - Choose Multiline Text in the Draw menu.
- Launch the MTEXT command.
You are prompted:
First corner for block of text:
- Specify the insertion point of the multiline text entity.
You are prompted:
Select Opposite corner for block of text or [Justification/Rotation angle/text Style/text Height/Direction/Width/Line spacing/Columns]:
- Specify the opposite corner of the text block to define the maximum width of the multiline text.
If Dynamic Dimensions are active, the height and width of the text field are displayed dynamically. Type the height and width in the dynamic dimension fields. Press the Tab key to switch; press Enter to confirm.
- Type @ in the Command line, then press Enter for non-wrapped (zero width) text (= unlimited line width).
The Text formatting toolbar opens right above the text block.
- Type the text.
The maximum line width is defined by the width of the text block as defined in step 3.
Press Enter to start a new paragraph.
- To conclude the command and close the Text formatting toolbar do one of the following:
- Click the OK button
- Press Ctrl+Enter.
- Click outside the MText entity.
Text formatting toolbar tools and settings
| Button or setting | Name | Description |
Text Style | Sets the text style. |
Text Font | Sets the text font. |
Text Height | Sets the text height. |
Bold | Creates bold text. |
Italic | Creates italic text. |
Underscore | Creates underscored text. |
Overscore | Creates overscored text. |
Strike | Creates a strike-through text. |
Uppercase | Converts selected text to uppercase. |
Lowercase | Converts selected text to lowercase. |
Annotative | Toggles the Annotative property. |
Line Spacing | Sets the line spacing. |
Columns | Arranges the text in columns. |
Toggle spellchecker | Toggles the Spell Checking for Mtext editor. |
Match Properties | Matches Mtext fragment formatting. |
Color | Sets the color. |
Oblique Angle | Sets the oblique angle. |
Width Factor | Sets the width factor. |
Character Spacing | Sets the character spacing. |
Undo | Undoes recent actions. |
Redo | Redoes previously undone actions. |
Stacked text | Creates stacked text (fractions, subscripts and superscripts). Note: See Formatting stacked text below for more information.
To create a subscript or superscript, insert the ^ character before the text that should become a subscript or after the text that should become a superscript. Then select the text and the ^ character and use the Stacked Text option. |
Special Character | Inserts special characters. |
Field | Inserts a variable field. |
Justify | Sets the text justification. |
Paragraph alignment | Sets the paragraph alignment. |
Background Mask | Adds a colored background. |
Toggle superscript | Creates superscript text. |
Toggle subscript | Creates subscript text. |
Ruler | Toggles the ruler display. |
Numbered and bullet lists | Creates numbered/bullet lists. |
OK | Closes the Text formatting toolbar and applies the changes. |
Cancel | Closes the Text formatting toolbar and leaves the MText entity unchanged. |
Multiline text justification
The red dot indicates the insertion point of the multiline text entity.
| Top left | Top center | Top right |
| Middle left | Middle center | Middle right |
| Bottom left | Bottom center | Bottom right |
Including special text characters and symbols
You can use control codes and Unicode strings to include special characters in text entities.
To include control codes, type 2 percent symbols (%%) followed by the special control code or character. A single percent sign is treated as a normal text character.
Special text characters
| Control Code | Unicode String | Result |
| %%d | \U+00B0 | Draws a degree symbol (º) |
| %%p | \U+00B1 | Draws a plus-or-minus symbol (±) |
| %%c | \U+2205 | Draws a diameter symbol (Ø) |
| %%k | \U+0336 | Starts to strike-through text. Repeat the code to stop. |
| %%u | \U+005F | Starts to underscore text. Repeat the code to stop. |
| %%o | \U+203E | Starts to overscore text. Repeat the code to stop. |
Symbols and Unicode strings
| Name | Symbol (*) | Unicode String |
| Almost equal |
\U+2248 |
| Angle |
\U+2220 |
| Center line |
\U+2104 |
| Delta |
\U+0394 |
| Electrical phase |
\U+0278 |
| Identity |
\U+2261 |
| Not equal |
\U+2260 |
| Omega |
\U+03A9 |
| Squared | ² | \U+00B2 |
| Cubed | ³ | \U+00B3 |
(*) If supported by the text font.
Spellchecker
When the spellchecker button (
) is activated, the spell checking is available in the Mtext editor. The misspelled words are underlined in red in real time. Right click the string to display spelling suggestions.
A warning message appears when a valid dictionary is missing. See the SPELL command.
Adding a background mask
- When creating or editing a multiline text entity, click the Background Mask tool button (
) on the Text Formatting toolbar.The Background Mask dialog box appears:
- Check the Use background mask option.
- Choose a color in the Fill color drop-down list.
- Choose Select color... in the Fill color drop-down list and choose a color in the Color dialog box.
- Check the Use drawing background color option.
- Define the Border offset factor, which sets the margin around the text for the background. The value is based on the text height and must be in the range 1-5. A factor of 1.0 fits the multiline text entity exactly.
- (Optional) Tick the Frame around a text option to create a text frame.
- Click OK to create the background mask.
Stacked fraction text can be formatted using the Stack properties dialog box.
Right-click the stacked fraction text, then choose Stack properties in the context menu. The Stack properties dialog box displays:
- Alignment: allows you to switch between Bottom, Center and Top.
- Style: allows you to switch Diagonal fraction, Horizontal fraction and Tolerance.
- Text size: adjusts the text size based on a percentage of the set text height. Enter a value or choose a value from the drop-down list.
