Reference Edit dialog box
The Reference Edit Dialog Box allows you to edit block references and externally-referenced drawings.
- Path
- Description
- Reference Name
- Preview
- Select nested entities
- Settings
Path
Displays the name of the path.
Displays the description of the path.
Reference Name
Lists the name of the block and nested blocks, if any.
Preview
Displays a preview of the current reference.
Determines how nested blocks/xrefs are handled.
- Automatically
- Includes nested entities automatically.
- Prompt
- Includes nested entities by selecting them after the dialog box is closed by pressing OK.
Settings
Determines how entities are treated during editing.
- Enable unique layer and symbol names
- Toggles the use of $0$ in layer and other names.
- Display attribute definitions for editing
- Toggles the inclusion of attributes.
- Lock entities not in working set
- Toggles locking of entities not being edited.
