BEDIT command
BEDIT command
Opens the Create or edit block definition dialog box.
Icon:
Alias: BE
Opens the Create or Edit Block Definition dialog box to specify a block to open in the Block Editor.
Note: The HIDEOBJECTS, ISOLATEOBJECTS, and UNISOLATEOBJECTS commands are enabled.
Related commands
  • BCLOSE command
  • -BEDIT command
  • BSAVEAS command
Related information
  • Create or edit block definition dialog box
