Coordinate reference system
A Coordinate System is a set of mathematical rules for specifying how coordinates are to be assigned to points.
The coordinate system is unrelated to the Earth. A Coordinate Reference System (CRS) is a coordinate system related to the Earth through a Datum. A Geodetic Datum is a model of the Earth that specifies a reference surface (Ellipsoid or Spheroid).
A projected coordinate reference system is the result of the application of a map projection to a geographic coordinate reference system. A map projection is a type of coordinate conversion. It uses an identified method with specific formulas and a set of parameters specific to that coordinate conversion method.
Coordinates may be changed from one CRS to another through the coordinate operation. Two types of coordinate operation may be distinguished:
- coordinate conversion, where no change of datum is involved and the parameters are chosen and thus error free.
- coordinate transformation, where the target CRS is based on a different datum to the source CRS. Transformation parameters are empirically determined and thus subject to measurement errors. (Geodetic, Seven parameters, Molodenksy...)
Geographic datasets are defined in geodatabase.xmlthat is placed in <User folder>\AppData\Roaming\Bricsys\BricsCAD\<RELEASE>\en_US\Support for Windows. The content of this file is composed of the 5 sections:
- CoordinateReferenceSystems
- Datums
- Ellipsoids
- Transformations
- ProjectionCodes and Methods
This section is the main XML node where all Coordinate Reference Systems are defined. It has many sub-nodes called CRS, each XML node must define a unique projected coordinate reference system and the necessary projected parameters.
The supported CRS projection types are described in the ProjectionCodes and Methods sections.
CRS node attributes:
Follow Table 1 of OGP Geomatics Guidance Note No 7, part 2
| Attribute name | Description | Units |
| epsg | Unique EPSG database id. | Integer |
| name | Human-readable name of CRS, Example: "WGS 84 -- WGS84 - World Geodetic System 1984, used in GPS". | String |
| codeSpace | Owner of CRS. It is optional. | String |
| x, y | Orientation of projected direction. Possible values:
 | String |
| xAxis, yAxis | Orientation of geographic direction. Possible values:
 | String |
| Greenwich | Greenwich Meridian relation. | Degree |
| proj | Projection method of CRS. Possible values:
 | String |
| AngleSG | Angle from Rectified to Skew Grid. | Degree |
| Azimuth | Azimuth of initial line. | String |
| FE | Easting at false origin, False easting. | Float-Point value in CRS units |
| EC | Easting at projection center. | Float-Point value in CRS units |
| FN | Northing at false origin, False northing. | Float-Point value in CRS units |
| FC | Northing at projection center. | Float-Point value in CRS units |
| LonI | The longitude of the western limit of the first zone of a Transverse Mercator zoned grid system. | Degree |
| Lat | Latitude of natural origin, Latitude of standard parallel. It depends on Projection method. | Degree |
| Lat1 | Latitude of 1st standard parallel. | Degree |
| Lat2 | Latitude of 2nd standard parallel. | Degree |
| LatF | Latitude of false origin. | Degree |
| LatC | Latitude of projection center. | Degree |
| Lon | Longitude of natural origin, Longitude of origin. | Degree |
| LonF | Longitude of false origin. | Degree |
| LonC | Longitude of projection center. | Degree |
| SF | Scale factor at natural origin. | Float-Point value, unity |
| SFIL | Scale factor on initial line. | Float-Point value, unity |
| SFPSP | Scale factor on pseudo standard parallel. | Float-Point value, unity |
| W | Zone width in longitude. | Degree |
| zone | Zoned Grid System. | Degree |
| units | Units of conversion result from geographic coordinates to projected. Example: "Meter", unit "Degree" means no conversion, Geographic Coordinate System. | String |
<CRS epsg="31468" codeSpace="OGP" name="DHDN / 3-degree Gauss-Kruger zone 4" y="Easting" x="Northing" Greenwich="0" proj="TMerc" Lon="12" Lat="0" SF="1" FE="4500000" FN="0" zone="4" units="Meter">For each node CRS there should be at least one sub-node Datum that refers via epsg or alias attributes to sub-node Datum in the Datums section. The sub-node Datum MUST have the id attribute of a unique CRS name. At least one of the epsg code and the alias of Datum must be valid.
| epsg | Unique EPSG database id. Example: "4326". | Integer |
| alias | Unique Datum name. Example: "WGS 84". | String |
| id | Unique CRS name: combination of Projected method and Datum. Example: "WORLD-MERCATOR". It related to CS-MAP, AutoCAD® names. | String |
| pjcode | Indicate code for the coordinate reference system projection method types. Corresponded to AutoCAD® projection codes. For example, 3 - Transverse Mercator, 44 - UTM, 45 - Transverse Mercator of Snyder formulation and etc. | Integer |
<Datum epsg="6314" alias="DHDN/3" id="DHDN/3.Gauss3d-4" pjcode="3" />
<Datum epsg="6314" alias="DHDN/2" id="DHDN/2.Gauss3d-4" pjcode="3" />
<Datum epsg="6314" alias="DHDN" id="DHDN.Gauss3d-4" pjcode="3" />Datums
This section is a main node where all Datums are stored. Datum is a combination of the Earth model (Ellipsoid or Spheroid) and the transformation method to model WGS84. A Datum node specifies common parameters and contains at least one inner sub-nodes Datum exactly one sub-node Ellipsoid. Each inner sub-node Datum should define a unique name within the id attribute and may specify transformation parameters to WGS84 model via sub-node Transformation that refers via epsg or alias attributes to a sub-node Transformation in the Transformations section.
| alias | Unique id. Example: "DHDN/3". It is related to CS-MAP, AutoCAD® names. | String |
| epsg | Unique EPSG database id. Example: "6314". | Integer |
| name | Human-readable name of Datum. Example: "Deutsches Hauptdreiecksnetz". | String |
<Datums>
<Datum epsg="6314" codeSpace="OGP" name="Deutsches Hauptdreiecksnetz ">
<Datum id="DHDN/3">
<Transformation epsg="1777" alias="DHDN/3_to_WGS84" />
</Datum>
<Datum id="DHDN/2" name="Deprecated - Replaced by DHDN/3">
<Transformation epsg="1777" alias="DHDN/2_to_WGS84" />
</Datum>
<Datum id="DHDN" name="Deprecated - Replaced by DHDN/2">
<Transformation epsg="1673" alias="DHDN_to_WGS84" />
</Datum>
<Ellipsoid epsg="7004" alias="BESSEL" />
</Datum>
</Datums>Ellipsoids
The Ellipsoids section is the main section where models of the Earth are defined. Each Ellipsoid node should define an identification by a unique name (alias) and a semi-major axis (a) and one of the following attributes at least: flattening (f), semi-minor axis (b) or eccentricity (e).
| alias | Unique id. Example: "WGS84". It related to CS-MAP, AutoCAD® names. | String |
| epsg | Unique EPSG database id. Example: "7030". | Integer |
| name | Human-readable name of Datum, Example: "WGS 84". | String |
| a | Length of the semi-major axis of the ellipsoid, the radius of the equator. | Float-Point value, strongly in Meter |
| b | Length of the semi-minor axis of the ellipsoid, the distance along the ellipsoid axis between equator and pole. | Float-Point value, strongly in Meter |
| f | Flattening | Float-Point value, unity |
| e | Eccentricity | Float-Point value, unity |
<Ellipsoid epsg="7008" alias="CLRK66" name="Clarke 1866, Benoit Ratio" a="6378206.4000000004" b="6356583.7999999998" f="294.9786982139" e="0.0822718542" />Transformations
This section is a main node where all transformation methods are defined. Supported Transformation methods are described in the ProjectionCodes and Methods sections.
| alias | Unique id. Example: "DHDN_to_WGS84". It related to CS-MAP, AutoCAD® names. | String |
| epsg | Unique EPSG database id. Example: "1673". | Integer |
| codeSpace | Owner of Transformation. It is optional. | String |
| source | Source Datum. | String |
| target | Target Datum. | String |
| use | Transformation method. Supported transformations using geocentric methods:
 | String |
| method | Methods of building of rotation matrix, if applicable, "PVT" is Position Vector Transformation, "CFR" is Coordinate Frame Rotation. | String |
| tX | X-axis translation. | Meter |
| tY | Y-axis translation. | Meter |
| tZ | Z-axis translation. | Meter |
| rX | X-axis rotation. | Degree |
| rY | Y-axis rotation. | Degree |
| rZ | Z-axis rotation. | Degree |
| dS | Scale difference. | Unity |
| xp | Coordinate 1 of evaluation point. | Meter |
| yp | Coordinate 2 of evaluation point. | Meter |
| zp | Coordinate 3 of evaluation point. | Meter |
| dtX | Rate of change of X-axis translation. | Unity |
| dtY | Rate of change of Y-axis translation. | Unity |
| dtZ | Rate of change of Z-axis translation. | Unity |
| drX | Rate of change of X-axis rotation. | Unity |
| drY | Rate of change of Y-axis rotation. | Unity |
| drZ | Rate of change of Z-axis rotation. | Unity |
| ddS | Rate of change of scale difference. | Unity |
| t0 | The reference epoch for time-dependent parameters. | Float point value |
| fallback | Alias of transformation from target datum to WGS84 datum. | String |
<Transformation epsg="1679" alias="Pulkovo42/2_to_WGS84" src="Pulkovo42/2" trd="WGS84" use="Param7" method="CFR" tx="-40.595" ty="-18.55" tz="-69.339" ds="-4.299" rx="-2.508" ry="-1.832" rz="2.611" accuracy="9" />ProjectionCodes and Methods
These sections describe the ProjectionCodes and Methods that are mapped to AutoCAD® definitions of projections and transformations types. They are used to store the definitions in an XML file of coordinate reference system definition inside the AcDbGeoData object that represents a geographic location.
