GEOIMPORT command
Imports a drawing with respect to the geographic location.
Imports a drawing with respect to the geographic location in the source and the target drawing.
Note: The geographic location must be defined in both the source and the target drawing.
            Method
This command displays the Open drawing file dialog box, which allows you to select either a Standard Drawing File (*.dwg) or a Drawing Exchange Format (*.dxf).
