The LookFrom control
The LookFrom control is a visual navigation tool in BricsCAD used to switch between preset view orientations, such as orthographic and isometric views.
By default, the LookFrom control is displayed in the top right corner of the graphic screen.
Note: The behavior of the LookFrom control can be customized by several system variables and user preferences. See the Using the LookFrom control article for more information.
The LookFrom control dynamically adapts to the available drawing area or current viewport to maximize workspace. Depending on the size of the BricsCAD window and the drawing area, the LookFrom control is displayed as follows:
  • In a large drawing area, the cube and compass are displayed.
  • In a smaller drawing area, only the cube is displayed.
  • In a very small drawing area, the LookFrom control is hidden.
The display changes automatically as the available drawing area changes.
