The Ribbon
The Ribbon is a set of tabbed toolbars, filled with tool buttons and other graphical control elements, grouped by functionality.
Use the RIBBON and RIBBONCLOSE commands to open or close the Ribbon.
The contents of the Ribbon depend on the current workspace and can be further customized using the Customize dialog box. See the Customizing the Ribbon article for more information.
Use the Search in Ribbon field located at the top-right of the Ribbon to quickly find a command in the Ribbon. The Ribbon updates as you type, highlighting the matching commands across all tabs.
Click the Interface Settings () button located at the top-right of the Ribbon to easily modify the interface. The RIBBONSETTINGSENABLED system variable controls whether the button is displayed or not. See the Interface Settings dialog box article for more information.
Certain commands, such as QDIM and ARRAY, open a contextual Ribbon tab that provides easier access to the command options. The contextual Ribbon tab closes automatically when you finish or cancel the command.
Tip:
  • Press and hold the left mouse button to open the drop-down menu on the flyout button.
  • Use the mouse wheel to scroll through the Ribbon tabs.
  • Drag the Ribbon by the dotted grip at its left edge (when docked horizontally) or top edge (when docked vertically) to undock it.
