Roaming a Network license on a client computer
A network license can be roamed to use BricsCAD® without connection to the license server (work outside of the office, at home, etc.).
When a network license is used on a client computer, the Roaming... button is displayed in the License Manager > Licensing information dialog box.
  1. If your computer is connected to the license server through a proxy server, click the Proxy Settings button to configure the proxy settings for a network license.
  2. Click the Roaming... button.
    The License Manager > Roaming dialog box opens.
  3. Enter the number of days you want to check out the license for roaming and click the Checkout button.
  4. (Optional) Tick the check-box if you want to automatically refresh the roaming period when your computer is connected to the server.
  5. Restart BricsCAD® to apply the changes.
