Offline/manual activation (Single/Volume license)
If your computer is not connected to the internet, you can activate the license manually via another computer that is connected to the internet.
Important:
- We strongly recommend activating BricsCAD® online.
- When activating offline, the license locks on the computer and Operating System, and the deactivation is not possible. For online activated licenses, deactivation and reactivation are unlimited.
- Launch BricsCAD®.
- Do one of the following:
- If you start BricsCAD® for the first time, click Activate in the BricsCAD Launcher dialog box.
- If you replace or upgrade an existing license, launch the LICENSEMANAGER command, click Manage License and click Modify....
- Click Activate manually... in the dialog box.
The dialog box opens.
- Copy the full content of the Computer Hostid (1) field.
- Log in to the Bricsys website with the computer connected to internet.
Make sure you log in with the Bricsys account which contains your licenses.
- Click your user name and select Manage licenses (2) in the drop-down menu.
- Hover over the license key you want to activate and click the pencil icon (
) (3).
The License details page displays.
- Click Manual activation.
- In the Host ID field, paste the host ID of the computer you want to install BricsCAD® on.
- Click the Activate button.
A license file is generated and made available for download.
- Click the Download License File button.
The license file BricsCADVxx.lic is downloaded to your default download folder.
- Copy the license file to the computer you want to install BricsCAD® on.
- In the dialog box, click the browse button (
). Open the folder where you copied the BricsCADVxx.lic license file to and select the file.
- Click the OK button.
BricsCAD® is launched.
