Revoke a BricsCAD license (limited operation)
Warning:
  • Only revoke a license if deactivation is not possible.
  • Support must be contacted first before revoking a license.
  • The revoke possibility is limited to two per key.
  • There is no return possible if you revoke a license.
Use this procedure to:
  • Migrate a network license to a new server.
  • Revoke a single or volume license that was manually activated.
  • Reactivate BricsCAD after a hard disk crash.
Important: When in doubt, submit a support request in the Licensing > Revoke license category. See also the How to submit a support request article.
To revoke a license:
  1. Log in to the BricsCAD website using the account that is associated with your license.
  2. Click the My Account icon () and select Manage licenses (1) in the menu.
  3. Hover over the license key of the license you want to revoke and click on the pencil icon ().
  4. Scroll down and click the X icon to revoke the license.
Note: If you are a Maintenance user, contact support to review your additional revoke request.
