Working in the Drawing Explorer dialog box
Adding a drawing folder
- In the sub-window of the Drawing Explorer main window, click the Add local folder... button.
The Browse For Folder dialog box appears.
- Do one of the following:
- To add an existing folder: select the folder you want to add.
- To create a new folder: click the Make New folder button.
- Click the OK button.
The folder is added.
- Drawings in the subfolders of the selected folder can be opened too.
- The parent folder(s) of the selected folder are greyed out in the drawing folder tree. Drawings in such folders cannot be opened.
Opening a drawing
To open a drawing in one of your favorite folders:
In the sub-window, open the folder of the drawing.
- Select a drawing.
A preview is shown in the Preview sub-window.
- Double-click the drawing.
- Right-click and choose Open in the context menu.
Logging on to Bricsys 24/7
In the Drawings pane, select Folders.
Click Logon to Bricsys 24/7.
- Fill out your username and password.
When logged in, all of your projects on Bricsys 24/7 are listed.
Opening a drawing from a Bricsys 24/7 project
Expand the project, then select the drawing folder.
- Select the drawing.
- Right-click the drawing, then choose Download in the context menu.
A Save File As dialog box appears.
- Select a folder and optionally rename the drawing, then click the Save button.
The drawing is downloaded and opened in the current BricsCAD session.
Copying definitions between drawings
- Open both the source and the target drawing.
Launch the Drawing Explorer dialog box.
In the source drawing, select the category you want to copy items from, e.g. Blocks.
(option) Adjust the view option of the Details pane, e.g. Icon View button (
). - Select the definition(s) you want to copy, e.g. a series of blocks.
Press and hold the Ctrl key to select multiple items.
- Press and hold the left mouse button to drag the selection set to the Open Drawings section of the Drawing Explorer.
Release the left mouse button when on the target drawing name.
The selected items are copied to the target drawing.
- Right-click and choose Copy in the context menu.
Select the same definition category in the target drawing, then right-click and choose Paste in the context menu.
- You will be prompted to overwrite items of the same name.
- Drag-and-drop is not supported for some definition categories, e.g. MultiLeader Styles, Visual styles, Render Presets and Page Setups.
