Image utilities
The IMAGEADJUST command adjusts the properties of images through the Properties panel.
The IMAGECLIP command clips images.
The IMAGEFRAME command toggles the display of the frame around images; sets the value of the IMAGEFRAME system variable.
The TRANSPARENCY command toggles the transparency of images that have a transparent alpha channel. The alpha channel is a special channel that handles transparency. When an image has an alpha channel on it, you can adjust the image's opacity levels and make bits translucent or totally see-through.
Clipping an image
- Do one of the following:
- Click the Clip Image tool button (
) on the Image toolbar or the Insert / Images ribbon panel. - Launch the IMAGECLIP command.
You are prompted: Select image:
- Select the image.
You are prompted: Enter image clipping option [ON/OFf/New boundary] <New boundary>:
Press Enter to accept the New Boundary default option.
- You are prompted: [Select polyline/Polygonal/Rectangular] <Rectangular>:
Press Enter to accept the Rectangular default option.
You are prompted: Specify first corner.
- Click a point to define the first corner of the clipping rectangle.
The clipping rectangle is dynamically displayed.
You are prompted: Specify opposite corner:
- Click a point to define the clipping rectangle.
The image is clipped.
Modifying the Image Frame setting
Using the Image Frame tool (IMAGEFRAME command):
- Click the Image Frame tool (
) on the Images toolbar or the Insert / Images ribbon panel. - Launch the IMAGEFRAME command.
You are prompted: Enter image frame setting <current value>:
- Type 0 to hide image frames.
- Type 1 to display and plot image frames.
- Type 2 to display but not print image frames.
Editing the IMAGEFRAME system variable:
- Open the Settings dialog box.
Go to Drawing / Underlays.
Set the FRAME system variable = 3: Use individual settings.
- Select the IMAGEFRAME system variable.
The options are:
- 0: Hide image frames.
- 1: Display and plot image frames.
- 2: Display but do not plot image frames.
Setting the image transparency
- Click the Image Transparency tool button (
) on the Images toolbar or the Insert / Images ribbon panel. - Launch the TRANSPARENCY command.
You are prompted: Select images.
- Select the images you want to set the Transparency property of.
You are prompted: Enter transparency mode [ON/OFF]<current mode>:
- Press Enter to accept the current mode.
- Choose On to switch the Transparency property of the selected images on.
- Choose Off to switch the Transparency property of the selected images off.
Transparency of the camera image: OFF (left) and ON (right)
Setting the display properties of an image
- Select an image.
- The properties of the image appear in the Properties panel.
- Go to the Misc properties category.
- The following properties can be set Yes or No:
- Show Image: shows or hides the image.
- Show clipped: sets the clipping boundary on/off.
- Clip inverted: inverts the clipping boundary.
- Background transparency: sets the transparency on/off.
