Rotating entities
The ROTATE command rotates entities at a specified point along a specified rotation angle or by an angle referenced to a base angle. The default method rotates the entities using a relative rotation angle from their current orientation.
By default, angles start at 3 o'clock (East) and increase in a counter-clockwise direction. If you want to rotate in a clockwise direction, you can enter a negative value.
- The Angular Base is controlled by the ANGBASE system variable, which in turn refers to the current UCS.
- The Angle Direction is controlled by the ANGDIR system variable, which sets the positive angle direction from angle 0 with respect to the current UCS.
General procedure
- Launch the ROTATE command.
You are prompted: Select entities to rotate [selection options (?)]:
- Select an entity.
Entities in set: 1
- Select more entities or press Enter to stop selecting.
You are prompted: Rotation point:
- Specify a point.
You are prompted: Rotation angle or [Base angle/Copy] <0>:
- Do one of the following:
- Specify a point.
- Type a value and press Enter.
The selection set is rotated.
Rotating a selection set relative to a base angle
- Select an entity.
Entities in set: 1
- Specify a point.
- Choose the Base angle option.
You are prompted: Base angle <0>:
- Click two points to specify the base angle.
- You are prompted: New angle <30.84>:
- Click a point.
The selection is rotated.
Rotating in 3D
- Launch the ROTATE3D command or 3DROTATE command.
- Select an entity.
Entities in set: 1
- Select more entities, or press Enter to stop selecting.
You are prompted: Specify first point on axis or define axis by [Xaxis/Yaxis/Zaxis/2Points/Object/Last/View] <2Points>:
- Press Enter to accept the 2points method to select the rotation axis.
You are prompted: Specify start point of axis:
- Specify a point.
You are prompted: Specify end point of axis or <use axis parallel to view direction>:
- Specify a point.
You are prompted: Specify rotation angle or [Base angle/Copy]: 45
