Using the LookFrom control
Using the LookFrom control you can switch between a number of preset view orientations, such as orthographic views and isometric views. By default, the LookFrom control is displayed in the top right corner of the graphic screen.
Note:
  • The NAVVCUBEDISPLAY system variable sets the display of the LookFrom control.
  • The USENEWLOOKFROM system variable turns on or off the use of the new LookFrom control.
The new LookFrom control
The new LookFrom control is enabled by default.
To use the old LookFrom control, set the USENEWLOOKFROM system variable to 0 and restart BricsCAD.
The LookFrom control is inactive and becomes active when the cursor hovers over it.
Inactive state Active state
The LookFrom control can be dragged or clicked, the current view can be rolled, the current drawing home view can be selected or one of the preset views can be selected.
Click different places on the LookFrom control to display the view from standard viewpoints.
Note:
  • Select a face or use the arrows to switch to standard orthogonal views: Top, Left, Right, Front, Back or Bottom.
  • Select a corner for angled views.
  • Click and drag the compass ring to rotate the view.
Select corner Select face
The LookFrom control dynamically adapts to the available drawing area or current viewport to maximize workspace. Depending on the size of the BricsCAD window and the drawing area, the LookFrom control is displayed as follows:
  • In a large drawing area, the cube and compass are displayed.
  • In a smaller drawing area, only the cube is displayed.
  • In a very small drawing area, the LookFrom control is hidden.
The display changes automatically as the available drawing area changes.
The old LookFrom control
Click the triangle shapes on the LookFrom control to display the view from standard viewpoints. By default, it includes Top, Left, Right, Front, Back, Top Back Left, Top Back Right, Top Front Left and Top Front Right.
Note:
  • As you pass the cursor over the LookFrom control, a small green square appears. The relevant icon appears at the center and a tooltip displays the view name below.
  • To access the Down viewpoints, press the Ctrl key while clicking the triangle shapes.
Setting the LookFrom mode
To set the LookFrom mode, right-click the LookFrom control and select Isometric mode (for working in 3D models) or Twist mode (for 2D drafting).
Using the LookFrom control in Isometric mode:
  1. Move the cursor to the LookFrom control.
    The LookFrom control becomes active.
  2. Hover the cursor over a view orientation.
    The chair in the center of the LookFrom control rotates according to the view orientation.
  3. (Optional) Hold down the Ctrl key to look bottom-up.
  4. Click to confirm.
    The view is rotated.
Using the LookFrom control in Twist mode:
In Twist mode, the LookFrom control rotates the view around the screen Z-axis.
  2. Move the cursor to the edge of the LookFrom control, on the left half for counterclockwise, on the right half for clockwise rotation. 15°, 30°,45°, 60°, 90°, 120°, 135° and 180° angles are available.
  3. Click to rotate the view.
  4. (Optional) Without moving the mouse, click again to rotate over the same angle again.
  5. (Optional) Move the cursor to the center of the LookFrom control, then click to restore an unrotated view.
LookFrom context menu
When you right-click the LookFrom control, a context menu with the following options appears:
UCS
Sets the current coordinate system.
World
Restores the WCS (World Coordinate System).
New...
Runs the UCS command.
UCS Manager
Opens the Drawing Explorer dialog box on the Coordinate Systems category.
View
Changes the current view.
Home
Changes the view to the home view. This option is available only after setting a view as home.
New...
Runs the -VIEW command to control named views.
View Manager...
Opens the Drawing Explorer dialog box on the Views category.
Perspective
Sets the perspective view mode.
UCSORTHO
Sets the UCS to follow the current view, and automatically switches the drawing plane to match the current view plane. For more information see the UCSORTHO system variable article.
Activate Home View
Set Current View as Home
Sets the home view based on the current view.
Visual Style
Sets the visual style.
Visual Styles Manager...
Opens the Drawing Explorer dialog box on the Visual Styles category.
UCS
Uses the current coordinate system (WCS or UCS) as reference coordinate system.
WCS
Uses the WCS as reference coordinate system.
LookFrom Settings...
Opens the Settings dialog box at the LookFrom section, where you can view and modify the related system variables.
Location
Sets the location of the LookFrom control.
Dismiss
Closes the LookFrom control.
Note: To restore the LookFrom control after closing, run the LOOKFROM command and choose the ON option.
Isometric Mode
Sets the LookFrom control to Isometric mode. This option is available for the old LookFrom control.
Twist Mode
Sets the LookFrom control to Twist mode. This option is available for the old LookFrom control.
LookFrom control settings
The behavior of the LookFrom control depends on a number of system variables and user preferences.
To access the LookFrom settings:
  1. Right-click the LookFrom control and choose LookFrom Settings… in the context menu.
  2. Run the LOOKFROM command and choose the Settings option.
View transition options
The following system variables control the behavior of view transitions:
  • VTENABLE: determines whether animated view transitions are enabled for zoom, pan and/or for view rotation operations.
  • VTDURATION: determines the duration of view transition animations in milliseconds.
  • VTFPS: defines the minimum frame rate required to allow animation. That is 7 by default, which means that the redraw time should take less than 143 (=1000/7) milliseconds. If the computer is not capable to redraw the view fast enough, no animation is available.
