-ARRAY command
Creates an array of entities.
Creates a static polar or rectangular array of entities through the Command line.
Note: Arrays can be created using 2D or 3D entities.
Method
There are two methods to create an array of entities:
- Polar
 - Rectangular
Options within the command
- Rectangular
 - Creates linear, rectangular, or square arrays.
- Number of rows in the array
Specifies the number of rows. (1)
Note: Enter 1 for a linear array and a negative number to draw the array downwards.
- Number of columns
Specifies the number of columns. (2)
Note: Enter a number value to draw the array to the left.
- Vertical distance between rows
 - Specifies the distance between rows of entities. (3)
- Spacing rectangle
 - Specifies two points that indicate the spacing between rows and columns. (4)
- Horizontal distance between columns
 - Specifies the distance between columns of entities. (5)
- Polar
 - Creates polar (circular) arrays.
- Base
 - Relocates the base point of the selected entities. (1)
- Center of polar array
 - Specifies the center point. (2)
- Number of items to array
 - Specifies the number of items in the array.
- enter to specify Angle between items
 - Specifies the angle between each copy. (3)
- Angle to fill
 - Determines the extent and direction of the array. (4)
- Rotate entities around the array?
Determines whether copies are rotated when they are arrayed.
- Yes
 - Rotates entities around the array. (5)
- No
 - Does not rotate entities around the array. (6)
