ALIGNSPACE command
Adjusts viewport angle, zoom factor, and pan position based on alignment points specified in model space and paper space.
Note: This command can be entered transparently during commands ('alignspace).
Note: This command works only in paper space.
Note: The model space viewports must have PERSPECTIVE mode OFF.
Adjusts viewport angle, zoom factor, and pan position by selecting points in the same model space viewport and paper space.
