AMBALLOON command
Adds balloon annotations for geometry, blocks or standard parts annotated with part references.
Method
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Note: The balloon annotation is added to the AM_5 layer.
Note: The balloon annotations are compatible with the legacy AutoCAD® Mechanical application.
Note: After opening a drawing that contains mechanical entities, filling other drawings with mechanical-related data will be done on-demand in contrast to previous versions. It will be possible when a user copies the mechanical-related entities to the vanilla drawing. In case of copying entities that are not related to the mechanical data, a vanilla drawing will not be filled with mechanical data.
Note: When you open a drawing that contains mechanical entities, but the LOADMECHANICAL2D system variable is OFF, a warning bubble is displayed at the status bar that describes the situation and provides a hyperlink to immediately enable and load the mechanical 2d modules.
Select the part references from the current BOM for which you want to add balloons.
Options within command
- auTo
- Adds balloon annotations for all selected part references at once.Note: The starting points for the balloon arrowhead leaders are inside the part reference symbols.
- One
- Adds balloon annotation for one-by-one selected part reference.
- set Bom
- Allows you to choose which BOM to use.Note:
- When no Bill of Materials (BOM) is present in the drawing, a BOM named MAIN will be automatically generated.
- Part references that belong to the chosen BOM are highlighted in red to be easily selected.
- The part reference balloon number is according to the BOM used.
- Lists the existing BOM in the drawing on the Command line.
