AMPARTLIST command
Inserts in the drawing area a parts list, according to an indicated BOM.
Icon:
Method
The command is available only for drawings that contain mechanical entities.
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Note: The Part List is added to the AM_5 layer.
Note: The Part Lists are compatible with the legacy AutoCAD® Mechanical application.
Note: After opening a drawing that contains mechanical entities, filling other drawings with mechanical-related data will be done on-demand in contrast to previous versions. It will be possible when a user copies the mechanical-related entities to the vanilla drawing. In case of copying entities that are not related to the mechanical data, a vanilla drawing will not be filled with mechanical data.
Note: When you open a drawing that contains mechanical entities, but the LOADMECHANICAL2D system variable is OFF, a warning bubble is displayed at the status bar that describes the situation and provides a hyperlink to immediately enable and load the mechanical 2d modules.
Specify according to which BOM you will create the parts list and place it in the drawing area. The Parts List dialog box opens to configure appearance and content of the table.
Options within the command
- Main
- Selects the main BOM for the part list.Note: The Main BOM table is current by default. The last used BOM table in the command is set as current.
- Lists all available BOM in the command panel.
