AMDATUMID command
Draws a datum identifier and attaches it to an entity.
Icon:
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Select the object to attach the datum identifier symbol and specify the points for its location, then the Datum Identifier dialog box opens. The first leader segment is perpendicular to the attached object.
When you double-click a datum identifier symbol, the Datum Identifier dialog box opens, allowing you to change its parameters.
After creating the datum identifier symbol with the AMDATUMID command, their properties can be changed also in the Properties panel:
- Symbol
- Drafting standard
- Displays the drafting standard.
- Standard revision
- Displays the standard revision.
- Scale
- Sets the note scale.
