ARRAY command
Creates an array of entities.
Icon:
Alias: AR
Creates an array by evenly distributing entity copies in a rectangular, path, or polar array.
Note: Arrays can be created using 2D or 3D entities.
Method
Select the entities, then choose the array type you want to create.
Note:
- The options in the Command line differ depending on the chosen array type.
- The default array type is saved by the ARRAYTYPE system variable.
Options within the command
- Rectangular
- Distributes entity copies into any number of rows, columns and levels (on Z direction).Note: For more information about the options for a rectangular array, see the ARRAYRECT command article.
- PAth
- Distributes entity copies evenly along a path into multiple rows and levels.Note: For more information about the options for a path array, see the ARRAYPATH command article.
- POlar
- Distributes entity copies evenly in a circular pattern about a center point or axis of rotation, using multiple rows and levels.Note: For more information about the options for a polar array, see the ARRAYPOLAR command article.
