ATTACHMENTSPANELCLOSE command
Closes the Attachments panel.
Closes the Attachments panel to hide it from the current workspace. If the Attachments panel is stacked when you close it, the Attachments tab or icon is removed from the stack.
Related commands
  • ATTACHMENTSPANELOPEN command
  • IMAGE command
  • PDF command
  • XREF command
Related information
  • Attachments panel
  • Panels
  • Workspaces
