-BEDIT command
Edits the entities that make up a block.
Edits the entities that make up a block in Block Editor environment, after introducing the name of the block to the Command line. Optionally creates a new block.
Method
There are two methods to use -BEDIT command:
- Edit an already existing block.
- Create a new block.
Options within the command
- Block name
- Enter a block name to open the Block Editor environment and start editing.
- Lists the existing blocks.
