-BIMCOLLECTDETAILSFROMSHEETS command
Collects all BIM details from named sheets.
Collects all the BIM details from the named BIM Project sheets and inserts layouts of these details as separate block references on the opened sheet.
Note: This command is available only in a BIM Project sheet.
Method
Name the BIM Project sheets one by one from which to collect all the details. Press Enter to finish the sheets selection process. All detected details are listed in the upper field of the Command line.
For details with multiple layouts, name a layout to be inserted.
Specify the base and second insertion points for the collection of layouts.
The inserted layouts hold a pointer to the sources of the details. This additional information allows the BIMCHECKDETAILS command to list and interact with the inserted layouts of the Project details.
