BASE command
BASE command
Changes the drawing’s base insertion point.
Icon:
Alias: BA
Changes the drawing’s base insertion point for when it is inserted in other drawings, usually as a block or external reference. The base point can be indicated using X, Y, Z coordinates in the current UCS or by picking a point in the drawing.
Related commands
  • INSERT command
  • -INSERT command
  • WBLOCK command
  • XREF command
Related variables
  • ANNOTATIVEDWG system variable
