BIMCHECKDETAILS command
Inspects the project details and their references.
The command opens a command context panel. This panel has a detail tree. For each project detail there is a node in the tree. This node has child nodes depending on the active space.
When the Model Space is active:
- Details with references
- Details without references
- Lists all details that have references. Each detail node has child nodes for every reference to that detail in the model.
- Lists all details without references.
When the Paper Space is active:
- Details with tags and layouts
- Details without tags and layouts
- Lists all details on the sheet that have tags and layouts. Each detail node has child nodes for every tagged detail reference and inserted layout on that sheet.
- Lists all details on the sheet that do not have tags and layouts.
Note: When you left-click a node, the corresponding elements in the model/paper space highlight.
A context menu displays when you right-click on a detail node:
- Link a detail file
- Allows you to reassign a detail file to a detail in the database.Note: It is available only when the detail file is missing.
- Insert detail layout
- Inserts a detail layout for the selected detail.Note: It is available only for sheets.
- Update layout
- Updates the inserted layouts.Note: It is available only for sheets.
