BIMFLOWCONNECT command
Creates a connection between flow segments.
Icon:
Creates a connection between flow segments, such as pipes or HVAC ducts.
Note: When more than 2 flow segments are selected, the axes of the selected segments must be coplanar. When multiple coplanar segments are selected, the connections are created. When two non-coplanar solids are selected, an extra connection element is introduced.
Options within the command
- Switch
- Switches between possible connections.
