BIMPROPAGATEPLANAR command
Propagates connections between planar elements.
Icon:
Planar elements accepted: walls, slabs, roofs.
Note: The detail of BIMPROPAGATEPLANAR will always be a 2D slice through a linear detail.
Method
Select planar reference solids that form the connection and, optionally, detail entities to be copied as part of the connection.
It can be used to copy detailed connections between two or more planar entities.
Note: The detail area to be copied is displayed in blue. The reference contact area is displayed in purple.
You can accept or reject suggestions by clicking on the tick.
- A green check mark means that the suggestion will be applied.
- A question mark means that the suggestion will not be applied due to one of several possible reasons.
- A red X mark means that the suggestion will not be applied.
Options within the command
- Inflate first
- Expands the sensitive zone to include similar solids which are not connected yet in the model. The edges of the initially detected detail are moved outward over a specified distance.
- Save detail
- Displays the Save Drawing As dialog box, which allows you to save the detail.
