BIMSTRETCH command
Stretches the ends of linear solids.
BricsCAD BIM
Stretches the ends of linear solids while maintaining previously made connections between other linear solids in the overall structure.
Method
There are two methods to use BIMSTRETCH command:
  • Stretch structural connections.
    Note: Stretching elements that are classified as Beam, Column or Member.
  • Stretch MEP connections.
    Note: Stretching elements that are classified as Flow segments.
Before using the BIMSTRETCH command make sure that:
  • Display sides and ends is enabled.
  • Display Axes is enabled.
  • Structural profiles are connected with StructuralConnect.
  • MEP connections are connected with FlowConnect.
Note: Before running the command, select the ends of the entities that will be modified.
Options within the command
Base Point
Specifies new basepoint to start the displacement from.
Copy
Makes a copy of the connected entities and places them in the new position.
Undo
Undoes the last action.
Exit
Exits the command.
