account
translation
Bricsys Help Center
BLOCKICON command
BLOCKICON command
Creates and updates preview bitmaps of blocks and stores them in the drawing.
Method
Type the name(s) of the block(s) to be processed. Separate block names by commas. You can use wild cards (? Or *).
Options within the command
Select all blocks.
Related commands
  • BEDIT command
  • BLOCK command
  • -BLOCK command
Related information
  • Creating blocks
  • Editing blocks
© 2026 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
