BLOCKSFROMCIVILPOINTS command
Creates blocks from selected civil points in the drawing.
Icon:
Creates block references from selected civil points in the drawing. The block is named POINT and includes the civil point attributes POINT, ELEV, DESC, and the insertion point. A separate block reference is created for the civil point symbol.
Method
Select the points to convert them to blocks or press the Enter key to convert all existing points in the drawing and choose whether to delete the original entities.
Options within the command
Yes-delete entities
Deletes the civil points from the drawing.
No-keep entities
Keeps the civil points in the drawing.
