BMBOMEDIT command
Edits an existing Bill of Materials (BOM) table in the current drawing.
Options within the command
- List tables
- Lists all BOM tables in the current drawing, from which you can select one to edit.
- Current bom
- Edits the current BOM table.
- Erase
- Removes the selected BOM table.
- Update all
- Updates all BOM tables.
- Erase all
- Removes all BOM tables.
- APPLY
- Applies the current changes.
- DISCARD
- Discards the current changes.
Note: See the BMBOM command for the full command options.
