BMMECH command
Converts the current drawing into a mechanical block.
Icon:
If the drawing contains block references or external references, they can also be converted into inserts of local and external mechanical blocks.
If the drawing is a mechanical block already, BMMECH does nothing.
Options within the command
- Yes - to convert all
- If the drawing contains block references or external references, all block references, external references and solids in the model space are converted to mechanical blocks and entities. Also, arrays of block references or external references will be converted into mechanical blocks.
- Blocks - to convert blocks
- If the drawing contains block references or external references, they will be converted to mechanical blocks. Solids from the model space will not be converted in that mode.
- No - to skip conversion
- The mechanical structure is initialized but blocks and external references are not converted.
