BMOPENCOPY command
Opens a copy of a mechanical block insert as a new drawing.
Icon:
Opens a copy of a selected external mechanical block in a new drawing.
If you open a copy of a parametric mechanical block, the current values of the various parameters are applied to the copy.
After saving it you may replace the original mechanical block with the newly created drawing using BMREPLACE command.
