BMREPLACE command
Replaces a mechanical block insert.
Replaces a mechanical block inserted in the current drawing with another one selected in the Select file for mechanical block dialog box.
Options within the command
- SIMilar inserts
Allows you to replace similar inserts automatically, depending on the selected option.
- Yes
- Replaces all similar inserts of the selected mechanical blocks in assembly.
- No
- Replaces the selected mechanical blocks only.
- mechanical block Type
Allows you to choose the insertion type for a replacement mechanical block.
- Local
- The new mechanical block is inserted as local.
- External
- The new mechanical block is inserted as external.
- Keep as is
- The new mechanical block inherits the insertion type from the replaced mechanical block.
- mechanical block Default
- The new mechanical block is linked as specified in its source file.
- Parameter changes
Allows you to control which parameter values will be used after the replacement is complete.
- Yes-reapply
- Parameter values of the replaced mechanical block are applied.
- No-use replacement as is
- Parameter values of the replacement mechanical block are applied.
- from FIle
- Allows you to select a DWG file from the Select file for mechanical block dialog box as the replacement mechanical block.
