BMSEQUENCEPANELCLOSE command
Closes the Sequence Manager panel.
Closes the Sequence Manager panel to hide it from the current workspace. If the Sequence Manager panel is stacked when you close it, the Sequence Manager tab or icon is removed from the stack.
