BMSEQUENCESTEPEDIT command
Edits a sequence step by adding or removing parts from it.
Method
Note: The command is available only for editing a step from a sequence.
Disclaimer
Sequence Manager is an experimental feature that may not yet be stable and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD.
Options within the command
- Add part
- Add parts to the selected step of the sequence.
- Remove part
- Removes parts to the selected step of the sequence.
