BMWELDSYMRETRIEVE command
Places welding symbols added to a welding feature in the drawing views.
Retrieves weld information (welding symbols) from 3D weld bodies that contain welding features. Weld information is created with Add weld symbol properties option from the context menu of a welding feature from the Mechanical Browser panel.
Note: This command is available only in Paper Space.
Note: This command only works for drawings that contain mechanical entities. To set the environment for BricsCAD Mechanical drawings, see the Overview of 2D Mechanical Drawings commands article.
Method
Select weld solid to retrieve its welding symbol.
Options within the command
- Auto
- Retrieve welding symbols created for all visible weld solids of the selected viewports.
