BSAVEAS command
BSAVEAS command
Opens the Save block definition dialog box.
Open the Save block definition dialog box to copy the current block definition to a new name. This command is only available from the Block Editor.
Related commands
  • BEDIT command
  • -BEDIT command
Related variables
  • BLOCKEDITOR system variable
Related information
  • Save block definition dialog box
