CHAMFER command
Creates chamfers at intersections, defined by two lengths, or a length and an angle.
Icon:
Alias: CHA
Creates a chamfer between two entities. The entities could be:
- Lines, excluding parallel lines
- 2D polylines, excluding parallel polylines
- The edge of a selected 3D solid or surface
- Rays, excluding parallel rays
- Infinite lines, excluding parallel infinite lines
The size of the chamfer is defined by:
- specifying two distances
- length and angle
Note: To connect two entities without creating a chamfer, hold the Shift key when selecting the second entity.
Options within the command
- chamfer Settings
- Opens the Settings dialog box at the chamfer parameters.
- Polyline
- Chamfers the vertices where two segments meet of the selected polyline (if applicable).Note: Creating chamfers on a hatch boundary created with individual lines (1) results in removal of hatch associativity. Associativity is maintained if the boundary is defined from a polyline (2).
- sOlid
- Chamfers all edges of a selected 3D solid.
- Angle
- Changes the method to length-angle.Note: BricsCAD measures the angle from 0 degrees, the X axis.
- Distance
- Changes the method to distance-distance.
- mEthod
- Specifies between angle and distance methods.Note: The program will keep using the same method for determining the chamfer until the method is changed again.
- Trim
- Determines if the entities are trimmed or extended to meet the endpoints of the chamfer line.
- Undo
- Undoes the last chamfer when in multiple mode.
- Multiple
- Create multiple chamfers with the same settings. Press the Esc key to exit the command.
- Enter surface selection option
- Selects which adjacent surface is the base surface that defines the edges that can be chamfered.Note: After you select the edge of a 3D solid or surface, the Command line prompts you to Enter surface selection option to indicate which adjacent surface is the base surface.
- Next
- Selects the next adjacent surface.
- Ok
- Sets the selected adjacent surface as the base surface.
- Select edge
- Selects only one edge (1) of the base surface to be chamfered.
- Loop
- Loops around selecting all tangential edges belonging on the base surface (2) to be chamfered.
