CIVILDWGEXPORT command
Exports BricsCAD Civil entities as native CAD entities.
Icon:
Opens the Save Drawing As dialog box which allows you to export Civil entities as native CAD entities in a new drawing. You can flatten all the entities to zero elevation while keeping the annotation of spot elevation or contour labels with the correct representation.
Options within the command
- Flatten entities
- Allows you to flatten all entities.
