EXPORT command
Exports data from the current drawing to a variety of file formats.
Icon:
Alias: DWFOUT
Opens the Export Drawing As dialog box to save the data from the current drawing to a variety of file formats.
These are the supported file formats for export, depending on the license level:
BricsCAD Lite
  • FBX binary file (*.fbx)
  • FBX ASCII file (*.fbx)
  • Lithography (*.stl)
  • Collada file(*.dae)
  • Windows Meta File(1)(2) (*.wmf)
  • Enhanced Windows Meta File(1)(2) (.*emf)
  • AutoCAD Drawing (*.dwg)
  • AutoCAD ASCII DXF (*.dxf)
  • Drawing Template (*.dwt)
  • Bitmap file(2) (*.bmp)
  • 3D DWF v6.01 (*.dwf)
  • Binary DWF v6.0 (*.dwf)
  • Zipped ASCII Encoded 2D Stream DWF v6.0 (*.dwf)
  • Compressed DWF v5.5 (*.dwf)
  • Binary DWF v5.5 (*.dwf)
  • ASCII DWF v5.5 (*.dwf)
  • Compressed DWF v4.2 (*.dwf)
  • Binary DWF v4.2 (*.dwf)
  • ASCII DWF v4.2 (*.dwf)
  • XPS DWFx (*.dwfx)
  • Scalable Vector Graphics (*.svg)
  • Micro Station DGN File (*.dgn)
BricsCAD Pro
  • Unreal Datasmith (1)(2)(*.udatasmith)
  • Rhino file(1)(2) (*.3dm)
  • 3D PDF (*.pdf )
  • Assembly ACIS file (*.asat)
  • Assembly ACIS file (*.asab)
Note:
  • Native export to 3D PDF and ASAT formats also support mechanical blocks, external references and solids.
  • EXPORT stores a scale factor in the SAT and SAB files relative to mm which will be used to scale while IMPORT, and creates the current SPATIAL ACIS format which cannot be imported into AutoCAD®.
BricsCAD BIM / Mechanical / Ultimate
  • IFC2x3 file (*.ifc)
  • IFC4 Reference View file (*.ifc)
  • IFC4 Design Transfer View file (*.ifc)
  • IFC4x1 file (deprecated) (*.ifc)
  • IFC4x3 file (*.ifc)
  • Revit Project (*.rvt)
Note:
  • BricsCAD BIM is officially certified for IFC4 Reference View (Architecture).
  • The IFC4x3 file (IFC 4.3.2.0) export format is available only when the Experimental mode is enabled.
  • The IFC4x1 file (deprecated) will be removed in a future BricsCAD release.
(1) Not available for BricsCAD for Linux.
(2) Not available for BricsCAD for macOS.
Note: If the EXPORT3DPDFWRITER system variable is set to 1 (Internal 3D PDF writer) and you save the drawing as a 3D PDF file, the Select exploded view dialog box displays:
  1. Select view: Allows you to select from the drop-down menu an Exploded view to export. Select No exploded view animation to export the document without animation.
  2. Animation: Toggles the export of exploded view with animation.
  3. Select all: Selects all steps of the exploded view.
    Note:
    • Steps can be individually selected.
    • Selected steps of exploded views are exported to 3D PDF as separate pages.
  4. Select FPS: Sets the required number of frames per second (fps).
Note:
  • When IFCEXPORTIDSPROPERTIESONLY system variable is ON, only the properties from the IDS-XML are exported.
  • Civil objects (surfaces, alignments) can be exported to IFC4x3 files.
  • Export to Binary DWF v6.0 (DWF file) takes into account only the Plot area of the layout or model space defined in the Page Setup. Therefore, everything outside the plot area will be removed and or clipped away.
  • The EXPORTMODELSPACE, EXPORTPAPERSPACE and EXPORTPAGESETUP system variables currently are dummies for DWF exports.
  • More 3D formats are available through a separate module, Communicator for BricsCAD. You can download it from the BricsCAD website.
    The import and export procedures using Communicator for BricsCAD are controlled through a series of user preferences. See the Communicator section in the Settings dialog box.
  • To export to a PDF format, use the EXPORTPDF command.
  • The EXPORT command supports components architecture based on regular blocks.
  • Geometry-only is available for export to RVT format.
  • When export the model as a Revit® project (RVT file), the entities are exported as Direct Shapes with classification.
