CIVILPOINTGROUPEDIT command
Edits Civil Point groups.
Icon:
This command allows you to change the name of the selected point group or delete it.
Options within the command
- Enter point group to edit
- Allows you to enter the point group name to edit.
- ? to list point groups
- Lists existing point groups in the drawing on the Command line.
- ? to list points
- Lists all points that are included in the selected point group on the Command line.
- Remove
- Allows you to remove the selected point group.
- rEname
- Allows you to rename the selected point group.
