CLIPDISPLAY command
CLIPDISPLAY command
Toggles the Clip Display property of section planes and BIM section entities.
Icon:
Note: The display of the section entity and be toggled also through the Properties panel.
Related commands
  • BIMSECTION command
  • LIVESECTION command
  • SECTIONPLANE command
Related information
  • BIM sections
  • Properties panel
