CLOSESHEETSET command
Closes the active sheet set.
Closes the current sheet set and restores the previously active sheet set in the Sheet Sets panel.
Note: You can also close the current sheet set by right-clicking its name in the Sheet list or Category views section of the Sheet Sets panel, then choosing Close Sheet Set from the context menu.
