-DESIGNTABLEEDIT command
Edits design tables.
Note: This command can be entered transparently during the commands (‘designtable).
Options within the command
eXport
Exports the content of a design table entity in CSV format file.
Replace
Replaces the content of a design table with data from a CSV format file.
Delete
Deletes a design table.
Configurations
Creates, removes, or views configurations.
Save current
Creates a new configuration as a copy of an existing one.
Remove
Removes a configuration.
? to list
Opens the Prompt History window. Displays a list of available configurations, the current one in use and the total number of configurations.
Parameters
Manages parameters.
Unlink
Unlinks parameters from the design table.
Link
Links parameters to the design table.
Note: (*) to link all: restores all initially existent but removed parameter links.
Clear expressions
Clears expressions (values and formulae) from parameters.
? to list columns
Opens the Prompt History window, then displays two lists and the total number of columns.
The first list contains the columns linked to the parameters.
The second list contains the columns not linked to the parameters.
Apply configuration
Creates a new row using the current values of variables.
? to list
Lists design tables attached to the current drawing.
