DCALIGNED command
Constrains the distance between two entities.
Icon:
Constrains the shortest distance between a point and an entity. Constrains the length of a line, a polyline segment, or an arc. Constrains the distance between two lines, making them parallel. Only the distance is constrained (locked); entities can still be moved (in tandem), rotated, and so on. Aligned constraints look like aligned dimensions.
Method
There are three methods to begin creating an aligned constraint:
- Entity
- Point & line
- 2Lines
Options within the command
- Entity
- Constraints the length of a line, a polyline segment or the chord of an arc.
- Point & line
- Constraints the perpendicular distance between a point and a line or polyline segment.
- 2Lines
- Constrains the distance between two straight linear segments. If the entities are not parallel, then the entity picked second is rotated around its midpoint to be parallel to the first entity.
